How to replace brake pads ?
[align=center]
How to replace worn brakepads[/align][align=center]
[/align][align=center]Click below[/align][align=center]
http://www.automedia.com/Replacing_B...cr20050701bp/1[/align][align=center][/align][/align]
[/align][align=center]Click below[/align][align=center]http://www.automedia.com/Replacing_B...cr20050701bp/1[/align][align=center][/align][/align]
Members What pads are you putting on your Monte when needed
How many miles are you getting on your brake pads
Are you using OEM
Please share your experience with the members
Thanks
[align=center]
[/align][align=center]Thanks members for posting about your brake pads rotors[/align][align=center]How many miles did you get from your OEM pads[/align][align=center][/align][align=center]_______________________________________[/align][align=center][/align][align=center]Hi Dan[/align][align=center]Good to see you online[/align][align=center]SpaceRiders account was corrupted when the site went down[/align][align=center][/align][align=center]TheSpacekid is starting all over again[/align][align=center]A Fresh start[/align][align=center][/align][align=center]Wish you and the reader a happy[/align][align=center]from Space[/align][align=center][/align][align=right]
Get outa here Space
[IMG]local://upfiles/4301/4EF058D0E050422F92F405C3105F09EF.gif[/IMG] [/align]
ORIGINAL: 04 Intimidator
The standard Powerslot Rotors and Hawk pads upgrade.
Whats up with the new profile Space?
Get outa here Space
I got about 80,000 miles out of my original pads and rotors. I replaced the rears right away at the dealer (goodwrench parts). The fronts I had to wait a couple of paychecks to do, and got them done at a local garage. About three months later I was getting a lot of brake chatter (about 6,000 miles later). I took it back to the local garage that did the fronts. They said that the front pads and rotors were worn, and replaced them. Anybody else have any fast break wear issues? The originals laster forever, so i'm not sure if it was just bad parts on the front.
Hi Ryan
Member Biggriggs
With normal driving you should be able to get 50 to 60K miles on
new brake pads
Fromyour post it seems your mechanic may have just put on new pads
without turning or replacing the rotors
I read that some new rotors can be bad
and it pays to get the best brake parts for stoppingyour Monte
A warped rotor will cause vibrations
Good Luck Ryan
Member Biggriggs
new brake pads
Good Luck Ryan
ORIGINAL: KidSpace
[align=center]
[/align][align=center][/align][align=center]_______________________________________________[/align][align=center][/align][align=center]No Dan, I want all the top ten[/align][align=center]LOL LOL LOL[/align][align=center][sm=happy046.gif][sm=groupwave.gif][sm=happy046.gif][/align][align=center][/align][align=center]Going for the GOLD[/align][align=center]LOL[/align][align=center]Sorry Members for highjacking my own Thread[/align][align=center]p.s. Dan hope thing R going Good 4 U[/align][align=center]Peace[/align][align=center][/align]
So in a nutshell you just wanted the top 2 poster spaces. Got it. LOL!
matthew41
Jan 25, 2015 11:22 AM
6th Gen ('00-'05): To replace or not to replace Fuel Pump Module?
Chris s
Jan 29, 2013 11:11 AM
ladybridgeport
Feb 1, 2012 10:46 AM
phoenix_iii
Mar 22, 2006 11:00 AM
