How to remove driver's seat with limited power?
Old Sep 23, 2022 | 01:37 PM
ouchthatshot's Avatar
Default How to remove driver's seat with limited power?
02 Monte SS 3.8l
The driver's seat moves about two inches towards the steering wheel only on the left side and not the side near the middle console. I obviously need to remove it to address that problem but can't get to the one bolt on the right side (near console) - any suggestions? The threaded "bolt" doesn't move on the right side which only allows the left side to move forward a couple of inches. I've checked for blockage (coins, et cet) but don't see anything. Appreciate the input/suggestions.
Old Sep 24, 2022 | 10:05 AM
Well, after watching other people manually move their electric seat, I found the hole on the driver's side.....I think it takes a #2 square drive bit to turn it manually. And then I found the problem.....the cable (below) wasn't attached to the other side of the seat causing that side not to move when applying electric. So, I gotta figure out why it came loose and re-attach it and see if I can move the seat with electric.
Old Sep 24, 2022 | 10:11 AM
Awesome that you posted the solution!
Old Sep 24, 2022 | 10:24 AM
Thx, and that's a hot looking SS with "a couple things."
Old Sep 26, 2022 | 09:04 AM
I was at a salvage yard once and was getting some seats out of the Car, when I paid for them the fellow asked why I didn't get he drivers seat, I told him is was powered and the car has no power he indicted some Hispanic folks use a 9Volt battery and hood it to a pig tail on the seat connector and it will move.
So I tried that took about three 9 volts batteries to get it out. If you can't get the bolt out with a star wrench on the one I took out I used a small ratchet wrench open on one side ratchet on the other
Glen01SS
Dec 31, 2020 05:23 PM
mr markuSS
May 9, 2016 05:34 PM
Scooby doo
Mar 20, 2011 03:21 PM
K-Mac Attack
Mar 22, 2010 09:22 AM
red04montels
Nov 7, 2009 08:15 PM
