5th Gen ('95-'99): Seat removal?
Old Jul 28, 2015 | 09:05 PM
mr markuSS's Avatar
Default Seat removal?
I have a 98 Monte Z34,I need to remove the driver seat to get under the carpet (dropped a tool).
I see some GM "genius" used Torx bolts to hold the seat to the floor.
While I can remove the front ones,the rear bolts seem to be totally inaccessible no matter how I adjust the power seat.
Any ideas?
Old Aug 1, 2015 | 04:17 PM
mr markuSS's Avatar
Never mind,one of the height adjuster motors came loose,blocking the seat from moving forward,used a screwdriver to lift it and got it.
Old Aug 1, 2015 | 05:45 PM
Talking
They can be fun to remove I have had them out a few times, and the Console is a fun one as well.
Old Aug 2, 2015 | 09:17 PM
mr markuSS's Avatar
I had the center console out today....not as bad as I thought. I'm still trying to resolve an issue with the shifter.
Old May 9, 2016 | 04:44 PM
Dale Parrack's Avatar
I'm having the same problem, only my seat is stuck all the way back and won't budge. Pretty difficult for my 5'1'' wife to drive lol. Is there a way to manually move it forward? Im pretty sure the motor is dead but can't access anything to even think about repair/replacement
Old May 9, 2016 | 05:00 PM
AndrewW's Avatar
You can see if this works for you to manually move the seat, I had to do this in a Buick once
Old May 9, 2016 | 05:12 PM
Wow, thanks for the quick reply!
So I stuck my head under there to try and figure out how to disconnect those flexible drive cables, and discovered the harness was disconnected from the 3rd motor! I have no idea how that happened, but I plugged it back in and everything works just fine.
Old May 9, 2016 | 05:34 PM
Here is a little tip I got at the Salvage yard. The fellow told me to use a 9 volt battery to hook up to the wiring harness clip and it was a success. I just unhooked the clip and plugged in the wire I got for the 9 volt at Radio Shack and it all worked. If you do this bring several with you it will drain the 9 volt I think it took 1 to go back and 2 to go forward.
MJClemm
Dec 15, 2013 12:05 PM
Zeke
May 28, 2012 09:09 PM
jay26
Feb 21, 2011 11:36 PM
allprorock
Oct 3, 2010 01:07 AM
dchawk
Feb 10, 2010 10:23 PM
