6th Gen ('00-'05): How is this possible?
Old Jan 2, 2015 | 10:21 PM
michelob's Avatar
Default How is this possible?
2001 SS
OK so the passenger headlight is wigging out. The bulb works for the turn signal but NOT for the running light? How is this possible? I mean if the bulb was bad it wouldn't work for either one? If it was the socket or wiring...again how it would work for one but not the other? Anyone else ever experience this? I don't even know where to begin to troubleshoot this?
Old Jan 3, 2015 | 12:14 AM
el pachuco's Avatar
The same bulb may be supplied from two different circuits. I had a similar problem with mine recently and had a hell of a time getting everything to function properly. I could see green corrosion in the connections and it took many baths with electrical cleaner and electrical grease to restore a good connection to get all of the circuits back to good.
A simple 12V lighted circuit tester proved to be invaluable in my trouble shooting. $6 at your local parts house.
Old Jan 3, 2015 | 05:54 AM
michelob's Avatar
Ah OK thank you sir. I will check the connection at the socket.
jessymo
Feb 19, 2009 10:07 PM
Dade652003
22
Oct 30, 2006 12:10 PM
roadshoptuner
Jul 30, 2006 09:54 AM
Dade652003
May 18, 2006 08:23 PM
Daddys Race Car
Nov 5, 2005 06:18 PM
