How do you reset change oil light
Done this yesterday. Called the GM dealership the they told me how to do this on my 2002 Monte.
without starting your car turn the Key to the second position. Make sure your radio it turned off and your fan. Then on your radio hold in the display button on the left hand side of the radio. it's also the tuning button for radio stations. Hold it in for a few seconds until the display says "Settings". Then you toggle the search buttons to what ever you want to reset. Oil reset is there along with other stuff you can do. The on the present buttons "1 and 2" toggle that to the reset then press the tuning button to finish/done. Your chime should go off telling you that you have reset what ever one you were on. Hope this helps, head is a little foggy this morning. :0)
Well that changes things. Since you have your factory radio, look in your owners manual and it will outline for you the procedures on resetting your oil life message.
I have a 2000 Chevy Monte Carlo. Both ways are correct. Key in EITHER the ACC or ON position for both ways. Does NOT have to be in the second position. Hold down display then scroll thru. Or pump gas pedal 3 times WITHIN 5 seconds. It should flash OIL RESET. But mine doesn't always buy still works with gas pedal. I have aftermarket radio.
