HOW DO YOU KNOW WHEN YOUR WATER PUMP IS BAD?
Old Oct 18, 2007 | 02:52 AM
motivation2k3's Avatar
Default HOW DO YOU KNOW WHEN YOUR WATER PUMP IS BAD?
HOW WOULD I KNOW IF MY WATER PUMP NEEDED TO BE REPLACED IN MY 2000 3.8 SS MONTE CARLO PACE CAR ? I ALSO WANTED TO KNOW IF A BAD WATER PUMP CAN CAUSE YOUR CAR TO OVER HEAT? NEED HELP ASAP
Old Oct 18, 2007 | 03:09 AM
Mrrench's Avatar
Default RE: HOW DO YOU KNOW WHEN YOUR WATER PUMP IS BAD?
There are a couple of ways on telling if your water pump is bad
1. Is it leaking anti-freeze?
2. Is it noisy when the engine is running?
Those are the two most common problems.
If your car is overheating, the first thing I would check would be thermostat. If it is staying the close position that would make your engine overheat.
Also make sure that the cooling fans are kicking turning on when the car gets to proper operating temp.
Make sure the radiator is not clogged,
Old Oct 18, 2007 | 11:15 AM
Twisted_Metal's Avatar
Nice car man, I'm lovin the matching rims ...
Old Oct 18, 2007 | 06:16 PM
GrandPaDave's Avatar
ORIGINAL: Mrrench
3. Does the pulley wobble when running or by manually tugging on it.
TMoney
Apr 9, 2014 09:32 AM
STUMPMI
Oct 9, 2013 09:03 AM
sportjunkee
Jan 13, 2008 07:13 PM
Brooke
Oct 17, 2007 04:35 PM
montejass
Apr 25, 2005 10:48 PM
