How to bypass ignition switch security?
Old Aug 14, 2011 | 05:22 PM
robin1977's Avatar
can you please get the all the info on bypassing the ignition security and any pictures that might be available thanks Robin
Old Jan 19, 2018 | 02:56 AM
Flaco's Avatar
Originally Posted by Nocturnx
I bypassed mine by measuring the resistance between the 2 wires and then soldering in a resistor. This tricks it into always seeing the correct resistance and therefore bypasses the security check. I have a guide and pictures if your interested in doing it yourself. Takes a couple hours, a multimeter, soldering iron, resistors and thats it.
How can I get a copy of how to bypass my 2007 monte. Have not been able to start it for 2 months now. I'm even thinking about selling to the jump yard.
Old Aug 11, 2019 | 10:52 PM
Randy Pyles's Avatar
Default I'm having terrible trouble out of my 2002 Monte Carlo changed the key switch and now
Originally Posted by slyon
can send step by step instructions losing paitiece with this car,,thanks
I have 2002 Monte Carlo and I changed the key switch into the ignition switch (wiring Harness) and now can't it to do anything...But it will start from the starter but will not stay running please help me bypass the security system
Old Mar 20, 2020 | 02:11 PM
Chris Grantom's Avatar
Default Bypass 2000 monte carlo security light
plz send what u have
Old Mar 28, 2020 | 08:11 AM
Jeffs02rwdSS's Avatar
His post is 12 year's old. Odds are they aren't active anymore.If you read through all the post's is tells you how to measure resistance at the switch with a multi meter and then match that with new resistors and cross your fingers it works.
C21sean
Oct 24, 2020 10:48 AM
MG426
Sep 20, 2015 08:02 AM
THISis3PIC
Sep 10, 2010 01:59 AM
poynter32
Feb 10, 2009 10:41 PM
splendidkiller
Oct 30, 2007 07:24 PM
