Hot Engine Steam Cold Radiator Cap
Old May 6, 2006 | 12:16 AM
USELESS's Avatar
Default RE: HOT BUT NOT ?
No, the first time it got HOT it did just that it NEVER Knocked or nothing. Why? would running Hot till it knocks make it more likely to blow a gasket OR crack the block? Not sure if any parts are aluminum, Thanks Again
Old May 6, 2006 | 12:34 AM
USELESS's Avatar
No, the first time it got HOT did just that got very HOT it never knocked or nothing. Why? is it more likely to blow a gasket OR crack the block if you let it get HOT till it knocks??? is that why you asked? Thanks again.
Old May 6, 2006 | 05:27 AM
DESS03's Avatar
ok to answer your question the intake and heads on his engine are aluminum the intake gasket is a pretty hard job to takle if you dont know what you doing bu thte shop i work at it is only about a 300 dollar job
because you have to replace upper and lower intake gaskets along with both valve cover gaskets
and adjust the valvesdont ask me why but gm made it where you have to remove the pushrods to change the lower intake gasket no one of there brightest ideas i say
Old May 6, 2006 | 09:14 AM
montejass's Avatar
I wonder if maybe it did get too hot and we might have a warpage issue and not so much a gasket/cracking issue.
Old May 6, 2006 | 01:29 PM
DESS03's Avatar
yes that is a possibility you cant rule it out but the heads on the 3.1 seem to be pretty resistant to warping i have seen a few of those engines get pretty warm
Old May 11, 2006 | 11:14 PM
USELESS's Avatar
Thanks to all you guys. Well ITS FIXED. Had the intake gaskets replaced paid a friend of mine $350 for it and alls GOOD now. Runs like new. All of you where a great help much much THANKS and maybe I'll be talking to you all real soon for other bits of advice here and there. Not to sure but I think my MONTE may need a trans tune-up soon LOL, should be no problem tackling it myself, can't be USELESS forever LOL, You All Been Great Thank You and Till Next Time, USELESS.
Old May 11, 2006 | 11:32 PM
montejass's Avatar
That is great news, I was worried that it was something much more than gaskets. Glad your back on the road again!!
Feb 1, 2013 07:35 AM
jwjones
Jan 3, 2012 10:56 AM
ashleymc34
Jan 25, 2010 10:41 AM
zipsayain
Mar 29, 2007 10:44 PM
GrandPaDave
Sep 21, 2006 07:18 PM
