Home link
Old Nov 11, 2010 | 10:33 AM
WV896's Avatar
Default Home link
I can't seem to program my overhead to open my garage door? Everything in the car is working but need the proper sequence I guess?
Old Nov 12, 2010 | 10:14 AM
RickAKATed10's Avatar
Photobucket
The Universal Home Remote System, provides a way to
replace up to three hand-held transmitters used to
activate devices such as gate operators, garage door
openers, entry door locks, security systems, and
home lighting.
If your vehicle has the Universal Home Remote
Transmitter, it complies with Part 15 of the FCC Rules.
Operation is subject to the following two conditions:
(1) this device may not cause harmful interference, and
(2) this device must accept any interference received,
including interference that may cause undesired
operation.
This device complies with RSS-210 of Industry Canada.
(1) this device may not cause interference, and (2) this
device must accept any interference, including
interference that may cause undesired operation of the
device.
Changes and modifications to this system by other than
an authorized service facility could void authorization
to use this equipment.
Operation
Do not use the Universal Home Remote with any
garage door opener that does not have the stop and
reverse feature. This includes any garage door opener
model manufactured before April 1, 1982. If you
have a newer garage door opener with rolling codes,
please be sure to follow Steps 6 through 8 to complete
the programming of your Universal Home Remote
Transmitter.
Read the instructions completely before attempting to
program the Universal Home Remote. Because of
the steps involved, it may be helpful to have another
person available to assist you in the programming ste
Keep the original hand-held transmitter for use in
other vehicles as well as for future Universal Home
Remote programming. It is also recommended that up
the sale of the vehicle, the programmed Universal
Home Remote buttons should be erased for security
purposes. See “Erasing Universal Home Remote
Buttons” later in this section or, for assistance, see
Customer Assistance Offices on page 7-4.
Be sure that people and objects are clear of the garag
door or gate operator you are programming. When
programming a garage door, it is advised to park outs
of the garage.
It is recommended that a new battery be installed in
your hand-held transmitter for quicker and more
accurate transmission of the radio-frequency signal.
Programming Universal Home Remote
Follow these steps to program up to three channels:
1. Press and hold down the two outside Universal
Home Remote buttons, releasing only when the
Universal Home Remote indicator light begins
to flash, after 20 seconds. Do not hold down the
buttons for longer than 30 seconds and do not
repeat this step to program a second and/or third
hand-held transmitter to the remaining two Universal
Home Remote buttons.
2. Position the end of your hand-held transmitter
about 1 to 3 inches (3 to 8 cm) away from the
Universal Home Remote buttons while keeping the
indicator light in view.
3. Simultaneously press and hold both the desired
Universal Home Remote button and the hand-held
transmitter button. Do not release the buttons
until Step 4 has been completed.
Some entry gates and garage door openers may
require you to substitute Step 3 with the procedure
noted in “Gate Operator and Canadian
Programming” later in this section.
4. The indicator light will flash slowly at first and then
rapidly after Universal Home Remote successfully
receives the frequency signal from the hand-held
transmitter. Release both buttons.
5. Press and hold the newly-trained Universal Home
Remote button and observe the indicator light.
If the indicator light stays on constantly,
programming is complete and your device should
activate when the Universal Home Remote button is
pressed and released.
To program the remaining two Universal Home
Remote buttons, begin with Step 2 under
“Programming Universal Home Remote.” Do not
repeat Step 1 as this will erase all of the
programmed channels.
If the indicator light blinks rapidly for two seconds
and then turns to a constant light, continue with
Steps 6 through 8 following to complete the
programming of a rolling-code equipped device,
most commonly, a garage door opener.
6. Locate in the garage, the garage door opener
receiver (motor-head unit). Locate the “Learn”
or “Smart” button. This can usually be found where
the hanging antenna wire is attached to the
motor-head unit.
7. Firmly press and release the “Learn” or “Smart”
button. The name and color of the button may
vary by manufacturer.
You will have 30 seconds to start Step 8.
8. Return to the vehicle. Firmly press and hold the
programmed Universal Home Remote button for
two seconds, then release. Repeat the
press/hold/release sequence a second time, and
depending on the brand of the garage door opener,
or other rolling code device, repeat this sequence
a third time to complete the programming.
The Universal Home Remote should now activate
your rolling-code equipped device.
To program the remaining two Universal Home Remote
buttons, begin with Step 2 of “Programming Universal
Home Remote.” You do not want to repeat Step 1,
as this will erase all previous programming from
the Universal Home Remote buttons.
Programming
Canadian radio-frequency laws require transmitter
signals to time out or quit after several seconds of
transmission. This may not be long enough for Universal
Home Remote to pick up the signal during programming.
Similarly, some U.S. gate operators are manufactured
to time out in the same manner.
If you live in Canada, or you are having difficulty
programming a gate operator or garage door opener by
using the “Programming Universal Home Remote”
procedures, regardless of where you live, replace
Step 3 under “Programming Universal Home Remote”
with the following:
Continue to press and hold the Universal Home Remote
button while you press and release every two seconds
(cycle) the hand-held transmitter button until the
frequency signal has been successfully accepted by the
Universal Home Remote. The Universal Home Remote
indicator light will flash slowly at first and then rapidly.
Proceed with Step 4 under “Programming Universal
Home Remote” to complete.
Using Universal Home Remote
Press and hold the appropriate Universal Home Remote
button for at least half of a second. The indicator light
will come on while the signal is being transmitted.
Buttons
To erase programming from the three Universal Home
Remote buttons do the following:
1. Press and hold down the two outside buttons until
the indicator light begins to flash, after 20 seconds.
Do not hold the two outside buttons for longer
than 30 seconds.
2. Release both buttons.
The Universal Home Remote is now in the training
(learning) mode and can be programmed at any time
beginning with Step 2 under “Programming Universal
Home Remote” shown earlier in this section.
Individual buttons cannot be erased, but they can be
reprogrammed. See “Reprogramming a Single Universal
Home Remote Button” following this section.
Home Remote Button
To program a device to Universal Home Remote using
a Universal Home Remote button previously trained,
follow these steps:
1. Press and hold the desired Universal Home
Remote button. Do not release the button.
2. The indicator light will begin to flash after
20 seconds. While still holding the Universal Home
Remote button, proceed with Step 2 under
“Programming Universal Home Remote” shown
For additional information on Universal Home Remote,
see Customer Assistance Offices on page 7-4.
Old Nov 12, 2010 | 02:29 PM
LuSe4's Avatar
Originally Posted by rickakated10
the universal home remote system, provides a way to
home lighting.
If your vehicle has the universal home remote
transmitter, it complies with part 15 of the fcc rules.
operation.
This device complies with rss-210 of industry canada.
device.
Universal home remote system
operation
do not use the universal home remote with any
model manufactured before april 1, 1982. If you
please be sure to follow steps 6 through 8 to complete
the programming of your universal home remote
transmitter.
program the universal home remote. Because of
keep the original hand-held transmitter for use in
other vehicles as well as for future universal home
remote programming. It is also recommended that up
the sale of the vehicle, the programmed universal
home remote buttons should be erased for security
purposes. See “erasing universal home remote
buttons” later in this section or, for assistance, see
customer assistance offices on page 7-4.
of the garage.
Programming universal home remote
follow these steps to program up to three channels:
1. Press and hold down the two outside universal
home remote buttons, releasing only when the
universal home remote indicator light begins
hand-held transmitter to the remaining two universal
home remote buttons.
universal home remote buttons while keeping the
universal home remote button and the hand-held
until step 4 has been completed.
require you to substitute step 3 with the procedure
noted in “gate operator and canadian
programming” later in this section.
rapidly after universal home remote successfully
5. Press and hold the newly-trained universal home
remote button and observe the indicator light.
activate when the universal home remote button is
To program the remaining two universal home
remote buttons, begin with step 2 under
“programming universal home remote.” do not
repeat step 1 as this will erase all of the
steps 6 through 8 following to complete the
receiver (motor-head unit). Locate the “learn”
or “smart” button. This can usually be found where
motor-head unit.
7. Firmly press and release the “learn” or “smart”
You will have 30 seconds to start step 8.
programmed universal home remote button for
The universal home remote should now activate
To program the remaining two universal home remote
buttons, begin with step 2 of “programming universal
home remote.” you do not want to repeat step 1,
the universal home remote buttons.
Gate operator and canadian
programming
canadian radio-frequency laws require transmitter
transmission. This may not be long enough for universal
home remote to pick up the signal during programming.
Similarly, some u.s. Gate operators are manufactured
If you live in canada, or you are having difficulty
using the “programming universal home remote”
step 3 under “programming universal home remote”
with the following:
Continue to press and hold the universal home remote
universal home remote. The universal home remote
Proceed with step 4 under “programming universal
home remote” to complete.
Using universal home remote
press and hold the appropriate universal home remote
Erasing universal home remote
buttons
to erase programming from the three universal home
remote buttons do the following:
than 30 seconds.
The universal home remote is now in the training
beginning with step 2 under “programming universal
home remote” shown earlier in this section.
reprogrammed. See “reprogramming a single universal
home remote button” following this section.
Reprogramming a single universal
home remote button
to program a device to universal home remote using
a universal home remote button previously trained,
follow these steps:
1. Press and hold the desired universal home
remote button. Do not release the button.
20 seconds. While still holding the universal home
remote button, proceed with step 2 under
“programming universal home remote” shown
For additional information on universal home remote,
see customer assistance offices on page 7-4.
x2!!! :d
Old Nov 12, 2010 | 03:25 PM
Photobucket
Originally Posted by LuSe4
x2!!! :d
lol ha!
Old Nov 12, 2010 | 05:50 PM
johnniep's Avatar
i had no luck with home link for the garage doors for the monte and impala, Ill try again some other day
Old Mar 16, 2013 | 01:06 PM
Darcem's Avatar
Vette no more
Feb 7, 2009 08:37 AM
lemkec
Jun 21, 2008 09:44 AM
knightfan26917
Oct 3, 2007 12:56 AM
2000_BLACK_SS
Oct 15, 2006 12:24 AM
