6th Gen ('00-'05): High beam issue
Old Nov 11, 2015 | 06:34 AM
Gene53's Avatar
Default High beam issue
Good Morning. I am having an issue with the high beams on my 2003 SS. They work fine if I pull and hold the multi-function switch, but will not latch on. All other lights work fine. If it is the multi-function switch what is a reliable brand to buy? I had bad luck with an AutoZone switch on another vehicle...it lasted 2 months....??? Thanks.
Old Nov 11, 2015 | 08:22 AM
turbo monte's Avatar
Definitely the multi function switch, not sure what brand people replace them with but I would assume acdelco or whatever is factory replacement and not the cheap off brand
Old Nov 11, 2015 | 12:08 PM
plumbob's Avatar
I agree with turbo. You get what you pay for and this is not a repair that you want to do over because of a cheap failed apart.
Old Nov 11, 2015 | 12:21 PM
Gene53's Avatar
OK, thanks for the replies. I've also had problems with NAPA electrical parts. It looks like the correct AC Delco part number is 88964581.
Old Nov 11, 2015 | 07:57 PM
plumbob's Avatar
That would be one of the correct numbers. GM Parts Direct also lists P/N 88964580. You might have to call a dealer to see what the difference is. I also see the price is listed at about $425. It's not like me to say this, but at that price I might think about another brand like Standard or Dorman for around $100. Check out RockAuto.com.
Old Nov 12, 2015 | 06:19 AM
Gene53's Avatar
The 88964581 does not have the cruise control function at the end of the stick. The 88964580 does.
