6th Gen ('00-'05): High beam issue
Good Morning. I am having an issue with the high beams on my 2003 SS. They work fine if I pull and hold the multi-function switch, but will not latch on. All other lights work fine. If it is the multi-function switch what is a reliable brand to buy? I had bad luck with an AutoZone switch on another vehicle...it lasted 2 months....??? Thanks.
Definitely the multi function switch, not sure what brand people replace them with but I would assume acdelco or whatever is factory replacement and not the cheap off brand
That would be one of the correct numbers. GM Parts Direct also lists P/N 88964580. You might have to call a dealer to see what the difference is. I also see the price is listed at about $425. It's not like me to say this, but at that price I might think about another brand like Standard or Dorman for around $100. Check out RockAuto.com.
