hesitation when going down the road
Old Sep 21, 2010 | 11:18 PM
nitehawkjcb's Avatar
So your gas gauge doesn't work? Get a new O2 sensor, it'll work wonders
Old Sep 22, 2010 | 06:45 AM
silverstreak's Avatar
i don't think i said the gas gauge doesn't work, but it doesn't anyway, that goes hand in hand with the pump though i looked and i can't just find the sending unit, which makes the gauge fluctuate
Old Sep 22, 2010 | 02:08 PM
The sensor is probably somewhere on your fuel pump assembly. I'm not sure, but you may be able to access it under your backseat? IDK about 6th gens, but on 5th gens you have to drop the gas tank.
Old Sep 22, 2010 | 05:49 PM
i can get to it through the trunk actually. i just ordered the whole pump just in case and the o2 sensor i'll pick up with the pump tomorrow so hopefully this gets the job done
Old Sep 23, 2010 | 09:40 PM
well i installed the new o2 and the fuel pump, i'll delete the trouble codes when i get into work tomorrow
Old Sep 23, 2010 | 11:07 PM
Is it running good?
Old Sep 24, 2010 | 06:48 AM
so far so good didn't drive it much, it was like 9 o clock last night by the time i slaped everything back together. i did take it for a lil test drive and everything seems to be ok, i just need to remove some codes now
Old Sep 24, 2010 | 07:59 PM
Removing the codes isn't that important. After 70-ish start ups, the code will clear itself. It does get to be a hassle always seeing that damn SES light though!
BeachBumMike
May 21, 2014 03:30 AM
el pachuco
Jan 31, 2013 01:28 PM
jimbo7
Dec 18, 2009 05:31 PM
superrod29
Sep 27, 2009 01:15 AM
Ds 01 MC
Jun 23, 2007 09:55 PM
