Here is a Auto dimming Rearview Mirror wiring diagram
Old Mar 28, 2021 | 01:25 AM
xpage's Avatar
Default Here is a Auto dimming Rearview Mirror wiring diagram
Please post a reply if you use this. Thanks!
Hello all,
There have been many threads asking about a auto dimming mirror's wiring diagram. I thought about putting in a auto dimming mirror in my Jeep YJ, since I'm so used to it on my monte. So I dug all around the internet and found multiple wiring diagrams that only give a bit of information. After cobbling many together I came to a solution. MIght be a few years late but now anybody can put one in their monte carlo or another vehicle
If you don't have ONstar, then you only need 4 wires. See my image below for details as some pins/wires switch depending on your options. I have my car's option codes listed on the right side, though I forgot to add I have UE1. Pin numbering is on the harness's connector on the mirror. I made a diagram on the top left just in case you can't see. More information is on the bottom left for some things.
Pin setup if you can't read my handwriting
Pin 1 - Gray - Goes to courtsey lamp control which grounds it, likely when you turn on the dome lights. Also maybe needed for BCM controlled theather lighting dimming? not needed for auto dimming --- may be white in some models
Pin 6 - Blue/white stripe - 12v input for light bulbs you can turn on and off, not needed for autodimming -- Maybe orange in some models
Pin 8 - Black - GROUND
Pin 9 - Light green - Reverse 12v input - Will unDim mirror when reversing and only when reversing. Need to connect to 12v that is energized only when reversing
Pin 13 - Brown - Ignition 3 voltage meaning voltage when key is set to ON, required for Auto dimming
MINIMUM SETUP -To have function lamps when buttons are pressed and to have auto dimming
Pin 6
Pin 8
Pin 13
Recommended setup - Removes auto darkening when reversing
Pin 6
Pin 8
Pin 9
Pin 13
Deluxe Setup -Probably for monte carlo's only, you get BCM controlled theather dimming
Pin 1
Pin 6
Pin 8
Pin 9
Pin 13
Ubowl
RWD Tech Guides '70-'88
Apr 27, 2015 07:06 PM
gmintimidator
Apr 3, 2012 02:44 AM
Vladimir
Nov 26, 2011 11:41 PM
MJClemm
May 18, 2011 07:19 AM
bilms01
Mar 13, 2007 04:35 AM
