Replaced map lights and still no light - mirror issue?
Old Jan 5, 2010 | 06:52 PM
gmintimidator's Avatar
Default Replaced map lights and still no light - mirror issue?
I've done a search and couldn't find an answer to my question. I have a 2000 SS with the dimming rear view mirror. I've replaced the 2 map lights with known good bulbs and still don't have a working light in the mirror. The auto dim function works correctly though. The wiring harness into the back of the mirror is something like 5 or 7 conductors. I probed them and had power at blue and brown. From the wiring diagrams I have seen, the blue is for the autodim function and the brown is for the interior lights. I am not sure what the rest of the wires are for. I am at a loss and assume my mirror is broken. Is there anything common on the mirror that can easily be checked with it in the car, or do I need to pull it out and open it up on my bench?
Old Jan 5, 2010 | 07:16 PM
turn the lights on, and then squeeze / pinch / move the wire around and see if they pop on.
Old Jan 6, 2010 | 09:02 PM
Thanks for the info. It did work. I popped the connector back in the other day and wiggled it around but it didn't help. After reading your post, I gave it another try. I was a bit more spirited with the wiggling and my lights popped on. Now just to fix my power mirror control that partially works!
Old Apr 8, 2011 | 06:35 PM
kent.michaelj's Avatar
Hey, I have a 2003 and I am having the same problem with the map lights not coming on. I can wiggle the wire and plug to get them to come on momentarily but as soon as the wire moves they shut off again. Any suggestions?
Old Apr 8, 2011 | 06:49 PM
Just keep playing with the wire, or you'll have to replace the connection, because obviously that's the issue.
Old Apr 9, 2011 | 03:25 PM
Is there a way to take the mirror itself apart. I took the plug off and tightened the connections and now the drivers side light comes on and stays on but i can't get the passenger's side light to come on at all.
Old Mar 24, 2012 | 12:53 PM
jjs777_fzr's Avatar
Can someone tell me the wiring color ordering for the connector ? As luck would have it I have a 2003 and 2004 - but the mirrors are not the same connector in the back. I'm looking for the 2003 mirror wiring - where the connector pinouts are numbered 1-7. What color to which number ?
Reason I ask..the mirror fell off and the wires separated from the connector.
Old Apr 3, 2012 | 02:44 AM
Jaythepunk's Avatar
Mine is doing that also. I have tried wiggling the wires but that rarely works. My dimming mirror has a strip at the bottom that doesnt dim so I'm gonna try and get a new mirror. Im pretty sure the guts inside are just wore out. I've had several cars with fancy mirrors and they have all broke.
Slayer11242
Mar 31, 2014 05:27 PM
LoriE
Feb 16, 2013 01:49 PM
hillzskillz13
Jan 24, 2012 03:57 AM
RosDaddy
Mar 14, 2010 01:47 PM
xkylex
Nov 1, 2008 11:20 AM
