Help wanted
I have a problem with my 85 monte ss. When I slow the car down , to say go around a corner the car seems to hesitate to pick back up. Even if i gun it. Is this a transmission, engine or vaccum line problem any hints are appreciated
Well thats an inexpensive start. Fuel filters as a rule need to be changed every 15,000 to 30,000 miles. This may not be your problem. In fact, it probably isn't. If the filter was clogged, you would not be getting fuel at all. Or very little. Not just during turning. TVW may have more insight on this.
As far as the fuel pump goes, mechanical pumps rarely cause problems. It would be in the fuel sender in the tank. The sender or pickup in the tank has a level sensor or in this case the float which determines fuel level in the tank. If something has broken or come loose or is hanging on in the tank, this could be your problem. You say it only cuts back during a turn and no other time. Does it seem hard to start?
I think you guy's are on the right track.
How many miles do you have on it? If you have not done a tune up on her in a while I would start there. Wires/Plugs/PVC/Filters.
At idle in drive, what RMP range are you running? Do you get a fluctuating RMP at idle?
If the carb has not been overhauled I would "Get R Done" as well. You may have a sticky float.
Filter...Yes. I agree with FD.
Would it hurt to change the fuel filter and pump.
no not really. I dont know if this makes sense but my dad has a 1986 mcss and driving his seems a lot smoother. I mean the gas pedal doesnt seem as stiff/heavy. Yes it only does this when turning. I have noticed it hesitating when you go to take off more recently. It is a summer only car that I got as gift from my dad 7 years ago it really hasnt been driven that much.
it has about 94000 on it. Carb was rebuilt in 2000 and plugs, wires, dist. changed in 2003. Cant remember exactly what rpm it idols at. I havnt drivin it since last June. But this problem has been ongoing for a few years now. NOTE: I have only put about 3000 miles on the car since 2002.
