Opinion Needed: Help with a stumble
Old May 26, 2015 | 10:44 AM
Ajohnson915's Avatar
Lightbulb Help with a stumble
I have an 04 Monte SS that has some stumbling issues: Only happens when it's warmed up, but intermittently. I am planning on replacing the Mass Air Flow sensor, only because it was the code that popped. No other issues besides the stumble. Anyone else had this problem?
I had a '96 Monte with similar issues that I ended up having plugs, wires, fule pump, filter and injectors done. I don't want this to end up like that.
Old May 26, 2015 | 12:18 PM
You can actually just try cleaning the MAF first, there is a MAF cleaner that you just need to spray on and let sit and dry.
Typically on warm startup the MAF is the usual culprit, and the code just helps with that.
Old May 26, 2015 | 01:15 PM
nitehawkjcb's Avatar
Agreed^
minicupracer1
Apr 25, 2015 05:39 AM
twfurst
24
Feb 22, 2012 12:50 PM
mattilus2121
May 27, 2009 07:01 PM
mattilus2121
Apr 16, 2009 03:52 PM
mattilus2121
Mar 31, 2009 02:45 PM
