Help! Rear end feels "Loose"
Old Dec 26, 2009 | 10:23 PM
Jed_377's Avatar
Default Help! Rear end feels "Loose"
Hey Everybody,
My fiance's 2000 Monte Carlo has a wierd problem. The rear end of the car feels "loose." On a dry road, the car drives normal. If the road is wet or snow covered, or if there is even slow blowing across the road, the car starts acting up. Does it while just coasting, when on the throttle, and when braking. The problem started all at once. She drove the car 250 miles, parked it for a day or two, and when she got in it to drive the next time it was doing this. I figured it was the rear brakes, so I changed them. New rotors, calipers, brake hoses and pads. The problem is still there. What could be wrong here? The back of the car seems to slide around on the road slightly, giving it the loose or squirly feeling. I'm stumped here. The car is a 2000, with 135k on it. She's owned it for quite a while, and this is pretty much the first problem its had. Any Ideas?! Please Help!!!!
Jesse
Old Dec 26, 2009 | 10:38 PM
Enzo354's Avatar
STILL SLOW
You might need to check all of the rods and such, mabye add a sway bar for added stabilty. You might even just have bad rear wheel bearings. Just park it on dry pavement and push on the rear quarter panel, and watch what the tires do, if they rock of if they slide. Having something loose back there could be real bad if it decided to become unconnected.
Old Dec 26, 2009 | 10:49 PM
Jed_377's Avatar
A couple other people I've asked said the wheel bearings too. I "shook down" the wheel on both sides and everything seemed tight. They roll easily and there is no noises. Somebody else mentioned an Alignment. All four tires are wearing strait and even. It puzzles me that the car was fine one day, and two days later its like this!
Old Dec 27, 2009 | 03:38 PM
wnmech's Avatar
I dont want to sound dumb but have you checked your tire pressures? Maybe expirment by rotating the tires and possibly also try raising or lowering the tire pressures? Just a thought
Old Dec 27, 2009 | 05:35 PM
nemesis's Avatar
2009 Monte Of The Year
i check the sway bars , rear trailing arms for worn bushing, strut mounts, or cracked sways also that would be my guess.
Old Dec 27, 2009 | 06:31 PM
sideways's Avatar
Also check the rear trailing arms, just did one on a friends car. sounds just like her problem. was broken in half about 2 inches back from the front bushing.
Old Dec 28, 2009 | 05:43 PM
Jed_377's Avatar
Could it have anything to do with the alignment? She took it to a shop and thats what they told her.
Mr.Monte
Oct 20, 2011 12:52 PM
bjorklund
Jun 23, 2011 10:47 PM
86 luxury sport
Jun 6, 2011 02:41 AM
kc2kth
Jan 16, 2011 12:42 PM
J-Bob
Apr 8, 2010 08:46 PM
