help with 2001 rear window defogger
Old Dec 25, 2009 | 06:38 PM
jedimcca's Avatar
Default help with 2001 rear window defogger
My son's 2001 MC SS rear window defogger isn't working now. The positive tab was knocked off and I soldered it back on. A couple of weeks later it was off again. This time I used the Loctite tab repair kit. Now, the tab is really stuck on but the rear window defogger isn't working. I measured the voltage across the pos and neg leads and it shows 14.8V. When it was soldered on the voltage was around 12V. I checked the relay and there is no way to tell if it is bad, gray plastic relay in the fuse box. I tried to measure the voltage in the middle with foil over my pos lead and I got 0V. That tells me that something is wrong. Any ideas?
Old Dec 29, 2009 | 01:49 AM
jedimcca's Avatar
Default don't buy the loctite tab adhesive
The stuff didn't work. It glued the tab on, but it didn't conduct electricity. I ended up pulling it off and soldering it again. It is working now. I just hope it doesnt' pop off again.
Old Dec 29, 2009 | 07:04 AM
sonin66's Avatar
you should be asking yourself how its popping out
Old Dec 29, 2009 | 07:44 AM
RocknSS04's Avatar
Just as an FYI to anyone else reading this, the Loctite brand repair kit has a poor rating. Google it and you won't find out much good about it. Loctite is a good company, too. It's a shame they have such a poor product in that item.
Glad you got it fixed.
Old Dec 29, 2009 | 09:39 AM
MAMONTE's Avatar
Glad you got it fixed. My defogger stopped working in my 06, but was fixed under warranty. The dealer said I had a bad connection.
01SSMonte
Jan 5, 2020 11:34 PM
Joester16
Jan 6, 2013 05:53 PM
monte carlo 3831
Jul 19, 2009 11:59 AM
duner
Oct 30, 2007 08:11 PM
oldnumber7
Nov 5, 2006 06:50 PM
