Rear end "wiggles" when i hit bumps on the road?
Old May 25, 2011 | 02:26 PM
bjorklund's Avatar
Default Rear end "wiggles" when i hit bumps on the road?
Hey, i've gotta 07 SS and if i hit a decent size crack in the road, the rear end feels like it wiggles left to right. Any ideas? Don't have any wheel bearing noise, and the bearings feel solid if i pull side to side on the wheels. It's just this really annoying rear end wiggle when i hit cracks in the road.
Old May 25, 2011 | 05:40 PM
My assumption is that you need to check all of your suspension parts for rust, make sure everything is tight, make sure all the bushings are okay. etc.
Old May 29, 2011 | 12:12 PM
04 JR's Avatar
the same thing is happening to me on my 04 dale jr. I had it looked at by a ceritified shop in the local area and I was told the rear trailing arms are shot. so I will be replacing my trailing arms with some BMR tubular trailing arms from 3800 performance.
Old Jun 7, 2011 | 08:07 PM
85SS - CY02's Avatar
Another item to check, your struts. My '02 would 'wiggle' going down the highway, without hitting bumps. New struts fixed it. Not saying it is them, but just something to think about.
Old Jun 8, 2011 | 07:05 AM
TheMonteMan's Avatar
only time i ever had this wiggle happen was driving a 1999 lumina recently. this happened at 90 driving cross country. got bad to the point i thought i had blown out a tire. pulled over to see the all tires inflated and rear trailing arm had rusted to the point that it broke.
Old Jun 23, 2011 | 10:47 PM
NovaSS369's Avatar
My rear end wiggled all winter, felt like I was driving a rear wheel drive honestly. The left rear trailing arm going from the wheel at an angle up to the frame was bent. Check all your trailing arms perpindicular and parallel with the vehicle.
bobwags
Aug 4, 2015 08:21 PM
sdowney
Oct 31, 2013 06:56 PM
Apr 3, 2012 06:53 AM
86 luxury sport
Jun 6, 2011 02:41 AM
Jed_377
Dec 28, 2009 05:43 PM
