help question
Old Apr 6, 2011 | 10:49 PM
thefuzz's Avatar
Exclamation help question
OK my 2000 monte ls runs great no problems BUT at times when the gas gauge gets down to about 1/4 tank when you go to put gas in it it WILL NOT TAKE GAS ! no mater what you do ! I have goten up to 2bucks in it then drove on down the road then as it got lower I thought I'm pressing my luck so here we go again ! GAS WENT IN JUST FINE ! this has happend of an on a couple times now what could cause this ???
thefuzz65@yahoo.com
Old Apr 7, 2011 | 08:39 AM
Either the gas station pump that you were using is bad.
Or you have a slight clog in your gas tank vent.
Old Apr 8, 2011 | 07:38 AM
thefuzz's Avatar
it has did it at a couple DIFFRENT stations ? the vent line how will I check it ? I'm asuming it is from the tank to the fill neck ??
jaydflash
Aug 29, 2014 03:38 AM
bbc
Nov 11, 2007 05:09 PM
ironmanxjr
Jul 4, 2007 02:01 PM
cj702
Aug 20, 2006 03:20 AM
