Help with fuse box under the hood
Old Apr 23, 2014 | 10:24 PM
JoeD's Avatar
Awaiting Email Confirmation
Default Help with fuse box under the hood
I was driving home oneday an I loss power to my fuel pump check every wire all the fuses changed then an still the same no power at all input power straight to the pump an works fine but then my fuse for fuel injectors blows so if I change the fuse box should I fix the problem of not getting any power
Old Apr 23, 2014 | 10:44 PM
Joe:
What year Monte Carlo?
What motor etc... need a little more info.
Thanks!
Old Apr 24, 2014 | 03:33 AM
JoeD's Avatar
2005 Monte Carlo an I did a L67 swap
Old Apr 24, 2014 | 08:25 AM
vikesfan's Avatar
trying to read through your post to determine what the issue is, without punctuation and the poor sentence structure it's a little difficult, so let me fix your post and then reply....
I have a 2005 Monte Carlo and I did a L67 swap. I was driving home one day and I lost power to my fuel pump.
I checked every wire and then changed all the fuses. And still the same, no power at all.
I put power straight to the pump and it works fine, but then my fuse for the fuel injectors blows.
So if I change the fuse box, should it fix the problem of not getting any power
if that is not what you meant to type, please let me know.
my reply....
which wire harness and PCM did you use for your swap?
how did you test the fuel pump and how do you know the pump works when you put power to it if the injectors blew when you did?
which fuel pump did you use in the swap?
what fuses where blown when it first happened?
ZIPPY02
Jul 15, 2014 08:51 PM
SoCal01Monte
Jun 25, 2012 10:30 AM
venomss
Jun 11, 2012 08:21 AM
venomss
Jun 9, 2012 01:58 PM
