5th Gen ('95-'99): Help
Old Aug 13, 2020 | 04:57 PM
Courtney Garrett's Avatar
Default Help
My 1997 Monte Carlo LS 3.1L, gave a code of P0305. Went and got my injectors replaced along with my spark plugs and wires of course. Drove it around and noticed that when I accelerate or am stopped, it hesitates and the check engine light comes on. Went to get it tested and the same code pops up, P0305. I literally just got everything replaced, is there another reason this code pops back up and is this something that I can do myself? I'm really not looking to give more money for something I can do at home.
Old Aug 13, 2020 | 10:17 PM
Steelbizkit's Avatar
What are the Possible Causes of the P0305 Code?
A thorough diagnosis can pinpoint the exact cause of code P0305. Common causes of the code include:
  • Ignition system problems (e.g.a worn spark plug or failed coil pack)
  • Fuel system problems (e.g., failed fuel injector or damaged injector driver)
  • Engine mechanical problems (e.g., a leaking valve or damaged lifter)
Note: If there are other codes stored in addition to P0305, the causes and symptoms may differ from those listed here.
bad coil, bad injector, bad injector wiring, bad icm/wiring, low compression due to ring or valve damage.
Just gotta diagnose it. Start by checking for fire at plug, then check to see if injector is firing, then do compression test.
Old Aug 14, 2020 | 06:43 AM
Sweet. I'll try these out myself and push come to shove, I'll end up regrettably taking to get looked at. Thanks!
owens91
13
Aug 17, 2015 05:11 AM
mc1978
28
May 9, 2013 03:25 PM
Boxman420
Jun 5, 2011 06:31 PM
Slimdadon101
Apr 22, 2011 01:52 PM
Blue_wolf
Feb 14, 2009 07:49 PM
