Check engine light while accelerating
Old Jun 5, 2011 | 04:24 PM
Boxman420's Avatar
Default Check engine light while accelerating
well this has been one hell of a week! my check engine light comes on randomly while accelerating. then the car will sputter and it wont really accelerate anymore untill the light goes off.. thankfully the light only comes on for about 5 seconds or so. but its annoying as ****. car only has 72k miles on it. which is ridiculous cause the wheel hub is bad and the gas gauge. god knows what else in the near future. anyways if anyone could point me in the right direction that would be fantastic. i love this car but if it keeps acting up its gonna have to go.
Old Jun 5, 2011 | 04:48 PM
l0gitech87's Avatar
Well your definately gonna have to get your car scanned with a scanner, not a code reader. If your saying that your CEL only comes on when you accelerate your gonna have to plug the scanner in and take the car for a ride to determine what the code is through Freeze Frame. The scanner will take snapshots at what speeds and how much voltage is being sent to the sensors TPS, MAF, MAP. I am pretty sure it will give you information on your fuel injectors which one is fouled (if it is). If your saying your having problems with your gas gauge it could most likely be fuel related. But to be honest it can be anything O2 sensor, or a plugged catalytic converter Good luck diagnosing, dont give up on your Monte yet
Old Jun 5, 2011 | 05:10 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
When I first put the turbo on my car, I had the spark plugs improperly gapped. The resulting condition was very much like you describe. When I hooked my scanner up to it I got a code that read something like, PENDING CODE: RANDOM MISFIRE: ALL CYLINDERS. When I regapped the plugs and reset the pending code, the problem went away. My CEL wasn't on even though it had a code "pending". Good luck!
Old Jun 5, 2011 | 05:28 PM
Boxman420's Avatar
well i did scann it while it was in the drive way(no CEL on at the time) but it didnt pull anything up. i did buy this car used at an auction so i dont know much about it before i got it. i have owned it for over a year and put just around 5k miles on it. i'm thinking im gonna do all new plugs and wires just for starters. i think i need to do that anyways and see what happens. thanks for the quick responses. i should probably check the CAT aswell
Old Jun 5, 2011 | 05:34 PM
bama_z34's Avatar
kinda sounds like your plugs have fouled out.
Old Jun 5, 2011 | 06:01 PM
Franks 03SS's Avatar
2011 Monte Of The Year
same thing happened with my old monte i used to own, one day while driving on the highway it started hesitating and i would give it gas and nothing, the CEL would come on and off and it felt like the transmission was slipping and missing gears, i even went as far as putting another transmission in it
in the end it turned to be the dang CAT
Old Jun 5, 2011 | 06:31 PM
Boxman420's Avatar
thats what mine is doing too. it just randomly doesnt want to go. but its not a daily thing. so im gonna have to get that checked out. hopefully wont cost to much
SanJoseSS
Feb 1, 2013 01:29 PM
ded548
Jul 29, 2010 03:11 AM
rgant_19
23
Jul 24, 2009 02:59 PM
anarchy1974
Dec 4, 2008 10:55 AM
mrl390
Dec 2, 2007 12:19 AM
