6th Gen ('00-'05): help
Old Jul 13, 2015 | 05:19 AM
shaggy's Avatar
Default help
Np check engine light on runs fine then won't run at all starts sputtering and stalls out
Old Jul 13, 2015 | 12:38 PM
aeceder's Avatar
Does it have enough fuel in it?
Have you checked to see if the MAF is working properly?
Maybe check the EVAP sensor?
Not sure, let me ask around to couple of buddies.
Old Jul 13, 2015 | 05:43 PM
bossross's Avatar
does it stall at idle or when you give it gas
I had an idle air control motor go bad stalled whenever I took foot off the gas
Old Jul 14, 2015 | 03:25 AM
shaggy's Avatar
Enough fuel yes and there no code or light on
Old Jul 14, 2015 | 03:26 AM
shaggy's Avatar
While giving it gas and at idle tak goes funky and shuts off
Old Jul 14, 2015 | 08:54 AM
Think he meant enough fuel reaching the injectors.
Weak fuel pressure or faulty pump?
My PCV valve failed before and I had very erratic surging and it would not stay running.
Old Jul 14, 2015 | 12:00 PM
JC Colon's Avatar
What Year and Engine!
Old Jul 14, 2015 | 01:55 PM
shaggy's Avatar
Originally Posted by jc colon
what year and engine!
01 3.8
Old Jul 14, 2015 | 03:37 PM
shaggy's Avatar
Well idk think the pump every time I had a pump goes it just goes no in between
Old Jul 19, 2015 | 08:34 PM
JC Colon's Avatar
Does it do this when it only when the engine is hot, only when the engine is cold, or all the time?
jaydflash
Aug 29, 2014 03:38 AM
cj702
Aug 20, 2006 03:20 AM
