Help
Old Jul 16, 2011 | 05:09 PM
lucky7173's Avatar
Default Help
JUST PURCHASED A 2000 MONTE CARLO SS -WEIRD PROBLEM
I TOOK IT THROUGH THE CAR WASH AND NOTICED WHEN IT GOT DIM/DARK THE DASH LIGHT THAT HAS THE ODOMETER READING AND P N D ETC. LIT UP AND THE RADIO LIGHTS WENT OFF COMPLETLEY DARK. IM AFRAID WHEN IT GETS DARK I WILL HAVE NO DASHLIGHTS AT ALL. THE SMALL AC LIGHT STILL WORKED AND THE CRUISE CONTROL LIGHT ON STEERING WHEEL, AND DOME LIGHT WORKED- O GOD HELP I BOUGHT THE CAR AS IS!!!!
Old Jul 16, 2011 | 05:59 PM
Possum's Avatar
My 2007 does the same thing, in order to conserve battery power - the lights on the dash periodically dim and then go back to normal brightness. I think there's something in the Owner's Manual about it.
Old Jul 16, 2011 | 06:08 PM
mrl390's Avatar
Make sure the dimmer switch is turned up enough. If the dimmer is turned down too far, the lights will be really dim when the headlights come on.
Old Jul 16, 2011 | 10:47 PM
alp312's Avatar
Lol wow. This just means you went in a car wash where it was dark inside, so it turned your headlights on. You have auto lights that happenes. When its dark outside, in order to see your odometer/speedo, it gets brighter when the lights turn on haha.
Old Jul 17, 2011 | 04:25 AM
lucky7173's Avatar
TOOK THE CAR OUT AT NIGHT TO SEE WHAT WAS GOING ON-NO DASH LIGHTS WORKING, THE ODOMETER LIGHTS AND RADIO LIGHT ARE REALLY DIM-THE "dimmer" SWITCH IS IN THE CORRECT POSITION-BUT NOW EVEN A BIGGER PROBLEM THE TAIL LIGHTS ARE NOT WORKING. BRAKE LIGHTS AND HEADLIGHTS WORK. NO TAIL LIGHTS IS A HUGE PROBLEM. COULD THIS BE RELATED TO THE DASH NOT WORKING?? AGAIN THANKS FOR YOUR HELP!!
Old Jul 17, 2011 | 04:49 AM
Hi Lucky & Welcome to the Monte Carlo Family.
Sorry to read that you are having a problem with your Monte
Does your Monte have any modifications ? Like new Deck, or any electrical additions from stock ? (like additional lights/amp's/speakers etc.
How many miles are on your Monte Carlo ?
Please check back later on your thread to see `if any of our expert Monte Tech's can assist in your problem.
Lucky, wish you Good Luck on locating your problem...
Old Jul 17, 2011 | 07:44 AM
Possum's Avatar
So how come the radio light went off?
Old Jul 17, 2011 | 08:09 AM
mrl390's Avatar
Im wondering if something is shorting out in your BCM. Ive heard of people having troubles with the BCM but I dont know exactly what symptoms they were having.
jaydflash
Aug 29, 2014 03:38 AM
cj702
Aug 20, 2006 03:20 AM
