HELP! 2004 SS overheating
hmmm, i was always told you flush it the direction of coolant flow. with water or coolant, whichever preferred... and of course its considered hazardous waste afterward. then you would hook it up and flush it the opposite way of normal flow to unlodge anything that settles in the direction of flow and then flush once more the normal direction. try flushing the radiator like that and see if it helps
Do you know if the t-stat opens? A simple way to check is feeling the radiator hoses. Grab a hold of the in-flow hose and feel for it to go from cool to hot. When this happens you know the t-stat is good because it opened up and allowed cooler coolant in to circulait around the block. I wonder if the t-stat is bad or you have a severe clog. You said the water pump, t-stat, elbows, were all good and no leaks. I also assume you are not losing any coolant.
To check for a plugged radiator. Place your hand on one side of the radiator and then the other. If one side is cool and the other warm, then the radiator is plugged. I was also thinking a head gasket problem. You can test that by doing a compression check. If two cylinders next to each other have way low compression, then the head gasket would be faulty. I would check the radiator first, though.
ss4me
10-06-2012 09:26 PM
