2004 3.4L overheating
Old Jun 3, 2012 | 07:55 PM
rob2000's Avatar
Default 2004 3.4L overheating
thanks in advance,
Im not sure if the problem is easy to diagnose.
things that have been replaced, or are not working
Water Pump about 7 months ago
Did a slight flush them
replaced harmonic balancer around the same time
replaced belt
ac not working at all, nor heater, vent etc. Bought a ac resistor that goes near the in dash motor, but i cannot fit under there very well.
been running hotter and hotter, then finally overheating. noticed sludgy rusty crud in the cooling system, tried flushing it twice and while a lot came out the inside of rad is still coated with this crud. used a in hose flush kit and the bottle of system flush
finally was able to replace the tstat after fighting with that crap layout. I put it all back together, filled it with coolant and something like water wetter. warmed it up and drove for about 10 minutes, it idled for about 20 minutes before i drove it and it was near the red, but below it 2 notches. sat at the red once i got to gas station and went red on the way back the mile drive to the house, with the high coolant warning lit in the dash.
while it was idling i did open the bleeder valves a few times. and let them bleed until just steam was coming out.
So do i still have air trapped in the system or is something else possibly bad, the fan turns on once its pretty warm.
hoping someone has an idea, as i cannot stand this car anymore. anything to fix is just a total sob on this thing.
ss4me
Oct 6, 2012 09:26 PM
rockin dude
May 26, 2010 12:10 PM
afterburn
Feb 8, 2008 07:49 PM
zx3adamania
Jan 12, 2008 06:36 PM
