Help! 05 ss drls running off of low beams?!?
Old Mar 20, 2013 | 06:58 AM
lunchboxor's Avatar
Default Help! 05 ss drls running off of low beams?!?
Hi Yesterday I installed my hids on my car. 3k fogs and 10k lows. On the last monte I owned, I had this same exact setup, and my drls wwere my high beams. Now on my 05, my drls are my low beams; my HIDs. Imaalmost certain its bad to have direct sunlight hit the hids while theyre on...Or something to that effect. How do I disable my DRLs, OR atleast get my drls to be my hi beams again?
fyi, if I flash my high beams, my highbeams DO go on, and stay on. I didnt do the wrong bulbs. and I have the correct bulbs aswell as 35w ballasts, all wired properly.
Old Mar 20, 2013 | 08:12 AM
In some models in 04 and all models of 05 they made the switch to low beams DRLs
Old Mar 20, 2013 | 08:35 AM
lunchboxor's Avatar
What are my options then? If I leave the switch pushed all the way in for auto beams, the drls(lows) come on. If I pull it to me once, they STAY on. another pull obv keeps on the lo beams
Old Mar 20, 2013 | 09:06 AM
Since you have an 05 you might be in luck and just need to pull the relay from the under hood fuse box.
Old Mar 20, 2013 | 02:02 PM
lunchboxor's Avatar
uh how do i do that? lol I have no idea whatcha want me to do
Old Mar 20, 2013 | 02:17 PM
Pop the hood, open the fuse box that is located under the hood, look for the relay that is marked DRL and take it out.
Old Mar 21, 2013 | 12:47 AM
lunchboxor's Avatar
Figured out a better solution. Pull the light tab on the left, next to the fog light button all the way to you, then put on high beams. At that point the highs stay on, and no power going to the bulbs. Driving with high beams on in the daylight isnt a ticketable thing in ny is it O.o
Cant see why not, whos gonna be able to tell the difference that theyre drls or not.
Old Mar 21, 2013 | 07:56 AM
How is that a better solution? Turning your lights on all the time, and then putting your highs on every time you start the car?
When people drive behind me with their brights on, even in the daytime, annoys me. When highbeams are DRLs they are limited to 50% brightness
Old Mar 22, 2013 | 05:38 AM
Code Red Monte's Avatar
i just pulled the DRL fuse and i have a 05 as well, it will not throw a SES light, i found a write up on this forum and how to do it and ive never had issues so far
edit found the topic
https://montecarloforum.com/forum/si...ictures-22464/
svzpt71
May 11, 2015 06:30 PM
jdubs81
Dec 16, 2014 07:42 AM
Ashleyp
Sep 14, 2014 02:31 PM
2004 ss
Aug 7, 2010 05:55 PM
mickey
Mar 20, 2008 06:15 PM
