Heater issues
Old Apr 20, 2013 | 12:52 PM
Colopam's Avatar
Default Heater issues
I have an 04 Monte Carlo with heater issues. Stopped working and replaces resistor. Seemed to fix the problem for about 1 month. Now it is working only sometimes.It seems lots of things are going on at one time. Speedometor will suddenly stop working the start again, same with tach.Begining to think it is haunted lol Any suggestions?
Old Apr 20, 2013 | 03:41 PM
ndaguanno's Avatar
It kind of sounds like an issue with your ignition cylinder, a few members have had problems with the accessories, when the ignition was replaced it solved there problems, so just a thought.
Old Apr 20, 2013 | 06:00 PM
Colopam's Avatar
Thanks ! I will check into that
Old Apr 22, 2013 | 01:03 PM
jim1405's Avatar
Actually, I would consider the ignition SWITCH first, then the cylinder if that doesn't fix things. It's the most likely culprit, is cheaper and you don't have the issue of getting a new ignition cylinder re-keyed. I had the same issues as you and more: abs light, brake light, security, airbag etc. all wigging out. Bought just the switch for about $40 and all problems were completely fixed.
Old Apr 22, 2013 | 09:25 PM
ndaguanno's Avatar
Thanks for correcting me I was thinking about the switch but said cylinder.
gelfuel
Nov 18, 2011 03:45 AM
gdogg090
Jan 31, 2011 03:46 PM
Chevycarlo97
Jan 27, 2011 11:45 AM
Rich
Apr 12, 2010 11:37 AM
rhythym7
Dec 27, 2008 08:58 AM
