heated seat switch-relay
Old Jan 7, 2009 | 08:56 PM
jeff2425's Avatar
5 Year Member1 Year Member
Default heated seat switch-relay
I have no current from heated seat switch to the harness under the seat. the switch lights on both high and low.where is the relay for drivers side switch located. I have an 02 LS and thank you in advance for any info and help.
Old Jan 7, 2009 | 10:36 PM
Enzo354's Avatar
STILL SLOW
Default RE: heated seat switch-relay
I would check the drivers side fuse box.
Old Jan 9, 2009 | 11:54 AM
jeff2425's Avatar
I found out the relay is under the seat and is not the prob. finally broke down and bought a mutitester and the seat bottom has .5 ohm resistence and seat back showed none or open and so I need a lthr. seat back cover. for info green connector or 2 wire is seat back. black conn. or 4 pin is seat bootom.
[IMG]local://upfiles/3966/D8B1F154844F4173AC12D766782AD45A.jpg[/IMG]
Old Jan 10, 2009 | 03:26 PM
RocknSS04's Avatar
You can put a jumper into the bottom connector to get THAT working again, at least until you replace the seat back leathers. They sren't cheap, but I believe there is a set of Intimidator SS seats for sale here for a freaction of the price of what just one piece of seat covering will cost you, and for that matter, you could sell the Intimidator headrests and re-coup some of the money back. Just a thot.
https://montecarloforum.com/m_109379/tm.htm
Old Jan 11, 2009 | 09:46 AM
jeff2425's Avatar
thanks rockinss04. I saved my christmas money and ordered a new cover on sat. gmpartsdirect was $253 with shipping. $100 cheaper than dealer. there is a good trim shop about 20 mins. away . my car has a side airbag will this be a problem for the install I hope it just plugs in and out. really really nice car you got there.
[IMG]local://upfiles/3966/BB32386B61CC44A894CBD0CC4EE1C3B2.jpg[/IMG]
[IMG]local://upfiles/3966/74FCBCA786FC49C68AFF56293C2B93B5.jpg[/IMG]
l67ss
Dec 3, 2013 12:22 AM
MJClemm
Dec 12, 2012 02:21 AM
03MonteCarloSuperSport
Sep 22, 2011 11:56 AM
cjp_ejp30
Dec 18, 2007 07:55 PM
tackett24
Nov 18, 2007 06:04 AM
