Heat on my Feet all Year
Old May 28, 2009 | 08:19 AM
hoosierdaddy68's Avatar
Default Heat on my Feet all Year
Greetings, new member here. I'm trying to find the cause of the heat that builds around my feet regardless of whether the heat or A/C are on in my 84 standard G-code Monte Carlo (305 V-8 Auto). The heater temp selector does work to make the air hotter or colder. It appears that the hot water is circulating all the time to some degree or other? Could this be the heater control valve, or is there a second valve for water flow in or around the heater box under the dash?
Regards,
Clarence
hoosierdaddy68@hotmail.com
Old May 28, 2009 | 09:01 AM
Hi Clarence,
Have you invested in a Auto Repair Manuel for your Monte ?
It's a great investment for the many parts on a car to assist in repairs.
Below are just a few suggestions/possibilites.
Please check back for one of our expert tech member's to read
and post their solutions/fix/opinions on your problems.
Be Patience...they visit thoughout the day/week.
_____________________________
1) The heat A/C head control unit has gone bad.
2) The solenoid bank has gone bad. (has many colored hoses connected to it)
3) There is a vacuum leak / no vacuum to the controls
4) The vacuum actuator valve is broke.
Old May 29, 2009 | 03:03 AM
Default Hot Feet
Thanks, KidSpace. The dash controls work to some degree at least-it gets hotter when you slide it to hot, cooler when slid to cooler but you notice it on hot days that the hot never entirely gets cut out. It has happened with my GF's 90 Blazer she bought new, so if we find the culprit here it may help troubleshoot that one too.
Old May 29, 2009 | 09:43 PM
kweef's Avatar
a slight vacuum leak in the the temp control could b a culprit. it would alter the vacuum and insure that the blend door would never completely move
Old May 30, 2009 | 05:15 AM
Thanks, Kweef! Nice car, too.
grizzlyaddams
Aug 9, 2011 05:38 PM
Emnasty600
Jul 2, 2011 09:38 AM
shineman08
Jun 12, 2011 02:14 PM
nemesis
Aug 2, 2010 12:50 PM
1WX27
Apr 24, 2008 07:26 AM
