Heat Issue
My heat in my MC only works when I'm driving after about 15 min & just recently my rear winshield defrosters have stopped working as well. Has anyone else had this problem & if so what do I need to do to fix it?
x2, sounds like your thermostat is stuck open which isn't allowing the car to warm up properly before coolant starts to flow through. I would pop a new one on there and bleed the system.
The defroster pins on the rear like to fall off on these cars. Autostores sell a repair kit for like 10 bucks
*edit* I moved your thread from the how-to section since it is for explanations of repairs and not general questions.
if you have recently worked on your cooling system, make sure you bleed the air out of the lines, my 99 3.1 is very tempramental, and has to be bled 2 or 3 times before everything works properly.
thermostat prob the cause tho... not real easy to get at, but definately a DIY project.
6th Gen ('00-'05): friends monte issue now my issue
thtGuy
May 7, 2013 08:09 AM
spike_monte
Nov 22, 2006 10:47 PM
USELESS
May 1, 2006 09:34 PM
