Heat Issue
Old Feb 10, 2011 | 11:29 PM
myronprescott's Avatar
Default Heat Issue
My heat in my MC only works when I'm driving after about 15 min & just recently my rear winshield defrosters have stopped working as well. Has anyone else had this problem & if so what do I need to do to fix it?
Old Feb 11, 2011 | 04:34 AM
monte07's Avatar
have you changed the thermostat and the back window defroster i would check the fuses and the wires. that hook up to the window and the baked on wires as well to see if there is no breake there
Old Feb 11, 2011 | 12:45 PM
cool i'll try that, thanks
Old Feb 11, 2011 | 12:48 PM
x2, sounds like your thermostat is stuck open which isn't allowing the car to warm up properly before coolant starts to flow through. I would pop a new one on there and bleed the system.
The defroster pins on the rear like to fall off on these cars. Autostores sell a repair kit for like 10 bucks
*edit* I moved your thread from the how-to section since it is for explanations of repairs and not general questions.
Old Feb 15, 2011 | 07:47 AM
AJMDowling's Avatar
i actually have the same problems. thanks this was really helpfull
Old Feb 15, 2011 | 09:41 AM
99inprogress's Avatar
if you have recently worked on your cooling system, make sure you bleed the air out of the lines, my 99 3.1 is very tempramental, and has to be bled 2 or 3 times before everything works properly.
thermostat prob the cause tho... not real easy to get at, but definately a DIY project.
thtGuy
May 7, 2013 08:09 AM
spike_monte
Nov 22, 2006 10:47 PM
CuttyKev
Oct 2, 2006 10:26 PM
USELESS
May 1, 2006 09:34 PM
mcarloss04
Nov 21, 2005 11:38 AM
