Headlights
Hi, I have a 2002 Monte Carlo SS with the lights on low beam the high beam light on the dash is on. With high beams on the dash light goes out. It is just backwards from normal. I checked the bulbs there are in the right spots
Were is the adj. for head lights side to side at on the head lights I got the up & down adj. Any ideas will be helpful.
Thank You
Rod
Thank You
Rod
