95 z34 blown head gasket
Old Apr 14, 2009 | 07:12 PM
z34monte95's Avatar
Default 95 z34 blown head gasket
Ok so I'm new here but active on cz28.com for years and a huge car guy, so im not a noob.
But i have a couple questions about my monte.
I bought a 95 z34, i bought it with bad head gaskets and wondering what to do, rebuild the entire motor, replace it with another 3.4 or swap in a 3.1 or a 3.8
Can anyone tell me what i would have to change with a 3.1 or a 3.8
Did a swap in a 2001 to a s/c 3.8 but this is a bit different.
Any help would be nice.
Thanks
Old Apr 14, 2009 | 09:37 PM
Actually not by much. Use a 98/99 monte Z34 harness, buy an "l67 swap harness adaptor" (just 2 simple plugs)- the only other oddball thing is you'll have to make a custom passenger side axle- use your stock outer and center shaft, and the HD inner.
Otherwise, its pretty much just like the 01. Any hoses and such you need- just buy replacements for a 98/99 monte Z34.
Old Apr 14, 2009 | 11:20 PM
z34monte95's Avatar
cool thanks!
Old Jan 31, 2014 | 09:28 PM
bronco1287's Avatar
Default Top of engine block gasket
Trying to figure out what this gasket on the very top of the engine block is called. It is not the head gasket. It is on the factory engine block from a 1995 monte carlo Z34 3.4 liter DOHC. it is this hard plastic gasket under a metal cover right over the opening of the camshaft. The opening on the very top of the block not the opening that you would remove the camshaft through or install it back into. I really dont want to just use copper spray to replace it, but going to have to if i can't figure out where to buy a new one. Reaqlly don't want to pay arm and leg at dealer for it.
monte ls
Jul 16, 2014 11:22 AM
InfamousFlip
Mar 14, 2013 04:11 PM
ajblalock
Jan 4, 2012 08:50 PM
1996Monte_Carlo
Jan 26, 2011 09:32 PM
Montecarloguy07
Dec 8, 2009 09:29 PM
