Having a whistle noise from the motor
https://montecarloforum.com/forum/mo...whistle-54423/
![Roll Eyes (Sarcastic)](https://montecarloforum.com/forum/images/smilies/rolleyes.gif)
Check above link & use of MCF Search Engine @ the top center of
each page.
Good Luck
each page.
Good Luck
It might be a tensioner bearing. With the engine off, try spraying a bit of wd40 or pb blaster around the bolt/washer on each of the tensioner and idler pulleys, then start the car and see what it does.
Does it run well? Are there any check engine lights?
I'm gonna suspect as mentioned a bearing in a pulley( could be an idler pulley, alternator, waterpump) or could even be as simple as the serpentine belt. funny coincidence but a friend drove his wifes car just Friday to ask me what was goin on, it was squeaking from the engine bay. by time I went to look at it the engine was cool, started it up and it sounded quiet as a mouse. gave it a few minutes to heat up and then the squeeking began. turned out to be waterpump bearing on his.
I however when I got my 06 monte also had a squeak but only at startup, would go away once engine warmed up. turned out to be just an aged belt. the belt looked good visually but I put a new goodyear belt on it and all was great.
