Have an Oil question..
so I am going to start running mobile 1 synthetic.... i have seen on the shelf the 15,000 oil...of mobile 1...does any one know any information about it that they could share...pros or cons...if it really works for 15,000...thanks
RE: Have an Oil question..
well they guarentee it for 15,000 miles but most filters will not last that long.
a wix filter will last 15,000 miles, whether you'd want to run this oil and filter that long is up to you
the oil i use is guarenteed that long but i still change it every 5000-7000 miles just to be safe
ORIGINAL: ozzy_osborn
great that is what i was going to do...thanks for your help again...you all are just full of knowlege
Now Wiz, how do I get back to Kansas?[sm=smokin.gif]
it is known that as oil breaks down, it puts more wear and tear on gaskets. i change my oil every 4000-5000 KMs just to keep it clean... its simple, if oil is clean, it works well, keeps engines clean and leak free.
the intake and head gaskets rarely go on the 3.8's compared to the 3.4's and the 3.1's
the 3.8l engine barely has any problems with intake and head gaskets
mstrmysterious63
09-25-2012 03:04 PM
Randy Biron
07-14-2012 08:07 PM
70monte1
25
01-19-2010 09:04 PM
