Has anyone really ever fixed a P0440 evap code
Old Sep 10, 2010 | 05:12 AM
tridski's Avatar
Default Has anyone really ever fixed a P0440 evap code
I have a 2002 SS. I have replaced the gas cap. Replace the purge solenoid, with no luck. I have checked for hose cracks, with no luck either. I guess I will try the vent valve next. Whats next. Thanks for any help. Dave
Old Sep 10, 2010 | 05:51 AM
Hi `Dave,
Check out the below link I had in my files.
Hope it helps,& check back to see what other
member's post for their repair on your subject problem.
Good Luck
http://repairpal.com/OBD-II-Code-P0440
Common Problems That Trigger the P0440 Code
Old Sep 10, 2010 | 09:03 AM
saigashooter's Avatar
Tune the PCM and have the code deleted, thats a sure fire way to get rid of it
Old Sep 10, 2010 | 09:20 AM
Blazed SS's Avatar
IT HERTZ
I had to do a code delete on my pcm
Old Sep 10, 2010 | 11:30 AM
labnjab's Avatar
The vent valve is the number one cause for evap codes in gm vehicles. Check your filler neck too. They sometimes rust where the cap goes. The neck is 2 pieces, plastic and metal and the metal separates from the plastic.
Old Sep 10, 2010 | 11:38 AM
Thanks Member's Brian, Keith & labNjab for your
help to other Monte Carlo family member's.
Sometimes we 4get to say thanks, but it's great to belong
to a forum & see so many member's helping each other.
It does not go un/noticed 4-Sure...
Wish the reader of this a `Happy
Peace/Out
`Dave, let us know if any of the above has helped.
Good Luck
Old Sep 10, 2010 | 03:41 PM
tridski's Avatar
I am going to order a vent valve. And check out the filler neck, and just try to dig deeper. I will let you know after the weekend. I hope I find something. Thanks for all the help. You guys are great. Dave
Old Sep 28, 2010 | 08:24 PM
tridski's Avatar
Well, no luck yet. I've tried two gas caps. I seem not to find the vent valve? I wish I could find a photo of the vent valve on the car. I tried to check the hoses, I cant find anything. Not sure what to do next. Thanks for all who helped.
Old Sep 28, 2010 | 08:47 PM
Old Nov 10, 2010 | 05:16 AM
tridski's Avatar
I finally got the vent valve on order. Now where is it on the gas tank. Am I going to have to drop the tank or can it be done without dropping it. Has anyone ever changed one. Once I get it in my hands I should be able to find it on the tank, just by comparing parts. Thanks for any help. Dave
