Hard Shifting when warm
Old Sep 15, 2008 | 07:07 PM
rysZ34's Avatar
Default RE: Hard Shifting when warm
That's actually a good thing to check if you can. Good call Enzo and welcome to the forum.
Old Apr 19, 2012 | 07:14 AM
mrittenhouse's Avatar
Did this problem ever get resolved? Just curios because I''ve been having the same issues for awhile.
Old Apr 19, 2012 | 08:38 AM
No longer an active member, thread is from 4 years ago.
Could be the transmission, could be the cat.
Old Apr 19, 2012 | 05:20 PM
aussiek2000's Avatar
Pressure control solenoid. Near 100% failure rate in 4t60e and 4t65e transmissions. Drop left side of trans, remove axle, pull cover of of side, replace solenoid. Code p1811 will verify this.
Old Jun 23, 2012 | 08:59 AM
QUEENIE976's Avatar
Unhappy Transmission
Once my transmission warms up it stops, you have to sit there for a minute and then it will slowly go into gear..drives fine when cold but once it warms up thats when the problem starts. Could this still be the torque converter? I pray that its not the whole transmission. Help!!!!!
Old Jun 23, 2012 | 10:41 AM
That is most definitely and internal trans problem. Time for a rebuild.
Seppeku
Oct 8, 2017 08:35 PM
mrgears
Sep 26, 2014 06:43 PM
Shayrae
May 6, 2014 02:09 PM
MontErie2012
Oct 23, 2012 09:34 AM
gkathleenw
Feb 29, 2012 11:03 AM
