Opinion Needed: getting the right engine
Old May 21, 2015 | 12:24 PM
KingWord's Avatar
Default getting the right engine
Alright guys as most of you know im in the process of swapping a 3.4 to a 3.8,my luck has been picking up on finding donor cars,i actually found a 2005 grandprix with an l36 about 10 mins away,the downfall is it has 192k miles,thats way too high,but she wants $600 for the complete drop out, I also found a 2002 totaled monte for $1000(I don't know any info on it yet)
I think I read somewhere that they changed some electronics on the 2004 and 2005 was different.is it true?
id like to stick with the easiest swap as far as electronics,im pretty much going for any engine available when I get the money either an l36 or l72,really wouldn't mind getting the l36 since people doesn't treat them as badly as a S/C engine
il probably have about $1000-$1200 to pick up a donor car within a month or so and im hoping to find a car with 100k miles at the most
Old May 21, 2015 | 01:11 PM
In 2003 there was an electronic change to the transmission, that would prevent your stock PCM from talking to a new transmission, but you would most likely be grabbing the donor PCM as well since you have the 3400.
In 2005 the grand prix is actually running a series 3 engine. The series 3 has an electronic throttle body, and returnless fuel lines. I would stick to a series 2
Old May 21, 2015 | 01:49 PM
KingWord's Avatar
is that the same for the 2005 monte's? il be grabbing everything I can under the hood,i was just wanting to make sure there wasn't any huge changes in the engines,im not that great with wires,i think $1000 should get me a pretty good motor and trans
im just trying to figure out what to do with all my old stuff,ive tried selling everything under my hood for $50 and nobody wants it,i guess il just take the block and tranny to the scrap yard and trash everything else
Old May 21, 2015 | 02:42 PM
turbo monte's Avatar
2005 monte carlo ss were all supercharged i believe and there a series 2 as well (l67)
Old May 21, 2015 | 02:55 PM
KingWord's Avatar
id rather just go with an l36 but I hate the fact that the uim is plastic
Old May 21, 2015 | 02:56 PM
The Monte was a different treatment. They stayed Series 2 engines in 2004 and 2005.
Grand Prix switched to Series 3 in 2004
There's nothing really wrong with the plastic UIM. It keeps heat down, and they have been plenty durable for me. Some have swapped to the metal UIM from the series 3, but I haven't found the need to do that yet.
Old May 21, 2015 | 03:01 PM
i was one of the guys that swapped to a aluminum plenum..... something about 20psi of boost inside that plastic plenum scared me lol
Old May 21, 2015 | 03:05 PM
KingWord's Avatar
haha and with an l36 it puts me in a good spot to run a turbo if I decide but after watching your vids Turbo, it really makes me want one
Old May 21, 2015 | 03:08 PM
lol thanks man, just an fyi though the l67 (supercharged engine) is actually better as it has lower compression pistons to handle boost better and the injectors on a sc car go into the heads instead of the lim. all you have to do to turbo a sc car is pull the sc snout and install a block off plate and install the turbo kit
Old May 21, 2015 | 03:19 PM
KingWord's Avatar
so the SC would actually be your UIM? that's neat
but if I go with a turbo I wouldn't want to stop there,since im already spending the money
did you have your engine built? or did you take it somewhere to get it bored over
you said yours is tuned on the street for 472whp id like to get somewhere between 400-420whp and that should make me happy
