getting air out of coolent..is this normal
Old Jun 25, 2009 | 10:45 PM
daves92camaro's Avatar
Default getting air out of coolent..is this normal
ok so the radiatior is filled and im running the car....and when i open the coolent valves to get the air out...some comes out...and it bubbles...then nothing...the 30secounds more comes out in like bubbles and then theres nothing...so do i have to keep the car running till a steady stream comes out??
its a 3100 v6 in a 1995 monte carlo ls..i just replaced the headgaskets and upper and lower manifold gaskets along with the thermostat
Old Jun 26, 2009 | 12:44 AM
MAMONTE's Avatar
I would get as much air as possible out, then just start driving it...
As you drive it, the remaining air should naturally work its way out, especially as the car heats up to operating temp. and then cools back down. The car will eventually get rid of all the air in the system, and will replace it with coolant from you over flow container. So make sure to keep a close eye on your coolant overflow, and keep it full.
Old Jun 26, 2009 | 08:16 AM
Try the valve on the thermostat, take a small screwdriver and unscrew it a little bit with a rag around it. do that until coolant starts to come out.
callie100
Oct 23, 2011 07:08 AM
daves92camaro
May 24, 2011 02:50 PM
Bcrusep
Mar 7, 2011 04:34 PM
Sciggy
Dec 18, 2007 01:35 PM
JMonte
Oct 3, 2005 03:06 AM
