Gen 5 rotor size
Old May 22, 2008 | 09:08 PM
PsuBrock's Avatar
Default Gen 5 rotor size
Whats up MCF community?
I was going to do my pads and rotors (who ever serviced the car put on garbage pads and should have done the rotors), and was puzzled that they suggest two rotor sizes for the 95MC. 267mm which = 10.5 inches, and 286mm which is 11.25 inches. Can anyone vouch that is safe to use the larger rotors, because the brakes need all the help they can get I'd like to use the larger rotor size. Thanks!
Old May 23, 2008 | 08:28 PM
PsuBrock's Avatar
Default RE: Gen 5 rotor size
C'mon the Gen 5 guys don't do their own brakes? Oh well I'm going to get the larger ones, I don't think they'd offer the size if it didn't fit, I'll update on what size rotors are currently in now and if there is a noticeable difference.
Old May 23, 2008 | 08:42 PM
scc24540's Avatar
edit:
you need to just measure the ones you have, if you install the larger rotors your caliper might not fit due to the enlarged rotor. but due to some research via the web it seems the larger ones are for the front, smaller ones for the rear for those with 4 wheel disc brakes
Old May 31, 2008 | 06:33 PM
04 Intimidator's Avatar
Otherwise goto summitracing.com, search for your car and they will give you what you need to know.
Crazy4408pac
Feb 17, 2011 06:43 AM
biggriggs
Apr 12, 2009 01:08 AM
04 Intimidator
Jun 8, 2008 10:51 AM
sorcier11
Jul 20, 2007 02:40 PM
BeachBumMike
Mar 4, 2007 03:44 PM
