Gear shift grinding...
Old Sep 24, 2007 | 10:46 PM
04 Intimidator's Avatar
Default RE: Gear shift grinding...
ORIGINAL: FlynhghR
Try some white lithium grease or some kind of lube you can get into the cable, Not WD 40... in a high heat application (like in the engine compartment, where it has to go) it will evaporate quicker than some "heavier" lubes (like white lithium grease) Trust me, WD 40 once killed my belt sander. (that booger gets hot, even when lubed well)
Good call. I've had this happen myself, but not when I've put it on an accessory belt in the car.
Very good safety call.
Old Sep 24, 2007 | 11:26 PM
FlynhghR's Avatar
Well, thank you! lol
oh, and GPD... was it for the climate control? I swear mine's getting louder and louder... you know when you switch from floor to face to windsheild defrost, etc...
Old Sep 24, 2007 | 11:27 PM
GrandPaDave's Avatar
ORIGINAL: FlynhghR
I'll try to find out what the exact part was, but I'll swear it was the sound of 2 plastic gears grinding.
Old Sep 25, 2007 | 08:33 PM
FlynhghR's Avatar
Ok, mine's not making a grinding noise really, just seems loud motor sound when moving.
Old Nov 18, 2007 | 05:27 PM
AlGeeEater's Avatar
ORIGINAL: allprorock
Sometimes when I go to put my car in gear in grinds an awful sounds. Seems like plastic on plastic but I'm not positive. It doesn't do it all of the time though. I can't even find a pattern to it. It still goes in gear it's just harder to get it there.
Anyone had this problem before?
I also think my automatic window motor is going out. I'm hitting a bad luck streak.
I'm having the same problem with an 01 SS. First my drivers side window motor starts going out, and then the same gear shifting noise is happening to me.
Old Nov 20, 2007 | 12:19 AM
FlynhghR's Avatar
Have you tried greasing the unit or removing the center/floor console? It's probably something simple, just that GM had to hide all the nuts and bolts make it harder to remove, lol.
That's where I would start....
turbo monte
Apr 4, 2013 10:01 AM
ralphtrent
FWD Tech Guides '95-'07
Jan 24, 2010 01:33 PM
george13
Feb 24, 2008 02:14 PM
fastback4
Sep 12, 2007 10:22 PM
canuck
Mar 18, 2007 12:29 PM
