2002 gear shift problem
Old Feb 23, 2008 | 08:37 PM
george13's Avatar
Default 2002 gear shift problem
this is my first post so bear with me. I have just been reading alot of the other postings. But my problem started about a month ago. without warning I got in my monte trying to put the car in drive it seemed hard but it went into drive with a litte harder pull.After getting where I was going the gear shift wouldn,t return to neautral,reverse or park. Then after letting the highly skilled alley machanic look at it,he lost a little plastic clip that looks like it was made for adjusting the cable.cant find that anywhere,even with the cable disconnected from the trans the gear shift in park the cable seems to be about a half inch to shortany suggestion to this problem I tired of going under my hood to change gears. and thatshard to dowhile driving lol.thanks in advance I LOVE this site.
Old Feb 24, 2008 | 05:46 AM
RocknSS04's Avatar
Default RE: 2002 gear shift problem
Welcome George from IN to the MCF family.
I had similar problems with my '01 SS LE. I took it to the dealer and they fixed it for not much. I didn't loose the plastic clip, but the shifter was not working correctly. Your's sounds a little more serious, tho. I'm guessing it's the shifter tho and not the tranny, if the tranny SEEMS to be working OK.
Old Feb 24, 2008 | 02:14 PM
george13's Avatar
thanks for the info but im trying to keep cost down i thinking the cable isbad in more suggestion like where to find that plastic clip
turbo monte
Apr 4, 2013 10:01 AM
02LS
Aug 23, 2011 10:13 AM
ralphtrent
FWD Tech Guides '95-'07
Jan 24, 2010 01:33 PM
fastback4
Sep 12, 2007 10:22 PM
canuck
Mar 18, 2007 12:29 PM
