Gear.
Old Apr 30, 2008 | 08:07 AM
98monte's Avatar
Default Gear.
What should I drive in the d with the circle around it which is overdrive, or should I drive i nthe D without the sircel around it? Which saves gas the best and what's the major difference.
Old Apr 30, 2008 | 08:55 AM
Default RE: Gear.
Hi `Tony,
The circle-surrounded "D" indicates thattransmission can use all of its gears, including an overdrive gear (gear ratio less than 1:1).
That is the setting you should use for 99.9% of your driving.
If you find yourself in a situation (usually on hills) where the transmission is frequently shifting betweentop gear
(probably 4th) and the next gear down (3rd?) and you find it bothersome, then shift into the regular "D". This will 'lock out' the top gear and reduce the number of shifts.
Another situation where you might use regular "D" is if you are going down a long hill at fairly high speed and want to control your speed without constantly using the brakes. Shifting into regular "D" will additional engine braking. If the hill is steep and speeds are low, you can use "2" or "1" or "L" (or whatever lower gear indicator you have).
Again, for the vast majority of your driving, just put it in O-D and forget about it. The transmission will shift when it's supposed to shift and you'll get the best MPG.
For a full explanation of how it works and when, see this excellent article in widipedia:
Good luck, from `Space
Old Apr 30, 2008 | 10:00 AM
rysZ34's Avatar
Default RE: Gear.
Usually city driving, a lot of stop and go I will drive in D, but highway and country driving I definitely use OD.
Old Apr 30, 2008 | 12:49 PM
98monte's Avatar
Default RE: Gear.
Thanks guys I was thinking that I read the manual, but it didn't explain it liek you guys have done, thanks space very informative.
turbo monte
Apr 4, 2013 10:01 AM
ralphtrent
FWD Tech Guides '95-'07
Jan 24, 2010 01:33 PM
Tiderfish
Jan 29, 2007 05:26 PM
erik2282
Oct 1, 2005 03:15 PM
ralphtrent
Aug 24, 2005 12:25 PM
