6th Gen ('00-'05): Gasket Sealant help
Old Aug 11, 2017 | 10:21 AM
MonteMan23's Avatar
Default Gasket Sealant help
So I've been making posts for about two weeks regarding over heating issues with my 05 Monte Carlo SS Supercharged and just the other day my coworkers and I found out I had a combustion leak. There's no white smoke, nothing wrong with the oil, but after burping the air out multiple times and it still overheating and doing the exact same thing regardless, we checked it out. We ran it with the cap off and my coworkers noticed how it spewed out coolant instead of circling it thru. I added k seal which did nothing so I wanted to know what is a better gasket sealant to hold me for atleast a month until I can get a new car ? If it help at all, once I turn on the heat the temperature doesn't reach the red mark on the end of the gauge it actually sustains for a while
Old Aug 11, 2017 | 02:03 PM
I would assume it's the head gasket at that point, nothing in a bottle is going to help.
Old Aug 11, 2017 | 06:55 PM
MonteMan23's Avatar
Well that sucks. Thank you!
Old Aug 11, 2017 | 07:09 PM
plumbob's Avatar
I've never been much of a believer in additives or stop leaks, but in your case all you have to loose in the money spent on the product as long as it doesn't mess up the cooling system (Radiator, heater core, etc...).
I saw Zippy boosting this K-seal stuff on a thread the other day:
Old Aug 11, 2017 | 07:16 PM
MonteMan23's Avatar
https://www.youtube.com/watch?
v=Zaqxp9_WwB8
Yeah I gave it a shot but to no avail. I was thinking bars stop leak
Old Aug 11, 2017 | 07:20 PM
plumbob's Avatar
That sucks, I've never used any of them. I heard K-seal is better than bars stop.
Old Aug 11, 2017 | 07:29 PM
MonteMan23's Avatar
I used Bar's on my firebird and I was able to drive it for a year without it over heating but for some reason the same don't go for my Monte Carlo. I've aready started looking into gettin another car which sucks
Old Aug 11, 2017 | 07:37 PM
plumbob's Avatar
Hope it's another Monte, good luck man.
Old Aug 11, 2017 | 08:07 PM
turbo monte's Avatar
Them gsket sealers in a bottle can do more harm than good. Either replace the gaskets or retire the car is the only real options here. Sounds like retirement is the choice and im sorry to hear
Old Aug 14, 2017 | 03:35 PM
DAVESS2002's Avatar
A lot cheaper to replace the head gasket than getting a new car! If everything else is good changing the head gasket and LIM can make it last another 100k miles.
