6th Gen ('00-'05): gas leak at nylon/plastic elbow
Old May 12, 2024 | 11:00 PM
04montess04's Avatar
Default gas leak at nylon/plastic elbow
hello all, i need help finding out what this white piece is called.
its leaking gas like crazy and needs replacement. is it a easy fix? any help appreciated!
Old May 13, 2024 | 08:26 AM
Is the actual plastic broken? Usually you can just replace the orings inside to stop leaks with these. But if the plastic or line is broken you will need to replace the whole end.
Old May 13, 2024 | 11:11 PM
i see thanks man, ok ill try the orings first. the white plastic connector thing and the line itself seems to be fine
Old Jul 31, 2024 | 01:47 PM
Frenchwg's Avatar
Default Fuel clip
There should be a u shaped clip that slides in at the bottom the fitting. Dorman makes them. Search for fuel line clip. Twice I've had this pop off and gas was pumping everywhere.
Old Jul 31, 2024 | 10:35 PM
thanks man! yeah that gas spraying out everywhere cant be good. i ended up replacing the oring and i got those dorman fuel line clips you mentioned and replaced that too.. once i got it all back on i heard a good click and no more leak as of now... hopefully i did everything right.
Old Aug 1, 2024 | 05:39 PM
Frenchwg's Avatar
Hope so too. I just keep a check on it now & then. I guess the clip loses tension over time.
Good luck.
Leprechaun93
Oct 4, 2022 07:36 AM
Mike Palatka
Feb 10, 2020 05:03 PM
Angela Caldwell
Aug 29, 2018 08:13 PM
wildcats62
Jun 17, 2012 02:50 AM
kingreyna
Feb 13, 2009 12:12 AM
