Antifreeze Leak
Old Jan 24, 2020 | 06:50 PM
Mike Palatka's Avatar
Default Antifreeze Leak
My 2003 SS Monte 3.8 is leaking antifreeze. I don’t se where the leak is at a quick glance.
Any suggestions?
Old Jan 24, 2020 | 10:41 PM
claydoh's Avatar
check the "elbows" on the top left of engine, they are in front of altenater originally plastic and famous for hidden leak problems, yo can replace with dorman aluminum elbows. with the car hot and running you can shine light there and see small but steady drips, its kind of a pain in *** to replace but well worth doing yourself if your handy, kinda pricey at a shop
Old Jan 25, 2020 | 07:24 AM
Thanks I’ll look at that today.
Old Jan 25, 2020 | 08:40 PM
Jeffs02rwdSS's Avatar
Easiest way to find is rent/borrow a cooling system pressure tester from a parts store and pressurize the system and look for the leak. A flashlight and a small inspection mirror will help you locate the problem . Good luck .
Old Jan 25, 2020 | 08:48 PM
I rented a pressure testing tool. The problem was the coolant elbow, one was leaking I replaced both with new metal elbows.
I didn’t put any sealer on the ends, is this correct? The original ones didn’t have any sealant on them.
Thanks everyone.
Old Jan 26, 2020 | 12:49 PM
I clean everything as good as possible with wire brushes and do put silicone on the also. If things are corroded it certainly doesn't hurt. Good luck.
Old Jan 26, 2020 | 04:10 PM
I put it back together with out any sealant. I did use the metal replacement elbows. I’m going to run straight water this week for a test and will drain and next weekend after I’m sure there’s no leaks. We’re not going to be near a freeze here so no loss either way.
Old Feb 8, 2020 | 08:24 PM
I replaced the elbows with a set of metal elbows that I bought at the local O’Reilly’s part store. I installed the new elbows without any sealant, just cleaned and put back together without sealant.
I drove the car for 102 miles a day, back and forth to work with water for one week with out any leakage. I drained the water and put antifreeze in and I have drove since without any leakage.
Thanks for everyone’s input and help.
Mike
Old Feb 10, 2020 | 11:13 AM
JackDW - 852's Avatar
Thanks for the update. It is good to know what fixed the issue. Many time people post issue on sites like this, requesting suggestions, but never come back and post what finally resolved the issue.
Thanks again for taking to time to post the fix.
Old Feb 10, 2020 | 05:03 PM
You’re welcome
shynativegrl
Oct 8, 2021 06:15 PM
tj4ndirish
Jul 26, 2013 10:05 AM
16With01MonteSS
Jun 14, 2012 05:19 PM
spyderbite37
May 7, 2012 08:16 AM
87lsman
Jun 6, 2007 01:56 AM
