Fuel Pump 5psi Low
Old Mar 5, 2013 | 11:51 AM
zombi86's Avatar
Default Fuel Pump 5psi Low
My mechanic said that my fuel pressure is about 5psi low. Is that enough to justify replacing the pump? The car likes to buck when accelerating. I had the cat converter tested and it was fine. Changed the plugs and wires a few months ago. Regular maintenance. 2002 Monte Carlo SS 100k miles.
Old Mar 5, 2013 | 12:42 PM
nitehawkjcb's Avatar
I'd change the fuel filter first
Old Mar 5, 2013 | 02:12 PM
Also pull the vacuum line off the fuel pressure regulator and see if that is wet or smells like gas
Old Mar 5, 2013 | 06:49 PM
aussiek2000's Avatar
Few pressure is pretty simple on these. Either you have enough to run or you don't. If it runs pressure is not an issue. Save your money.
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
robknight13607
Mar 20, 2013 09:14 AM
StanzManianDevil
Feb 22, 2009 11:28 PM
StanzManianDevil
Dec 24, 2008 06:46 PM
