04 supercharged SS Cruise control issue
Old Sep 15, 2010 | 07:21 PM
nelskin406's Avatar
Question 04 supercharged SS Cruise control issue
Just purchased a used 04 SS Monte with 110k and the cruise does not work, the on/off button seems to light up and function. So I went to the boneyard and got a used cruise box and changed it out with no results. I have read alot about the bcm symptoms and it doesnt quite seem to fit into that category yet? both 2amp fuses looked good, do I need to look at replacing the steering control button... or is this the beginning of the end of my bcm...any advice would be greatly appreciated
Old Sep 16, 2010 | 04:44 PM
lucian*91's Avatar
check your third brake light. if the 3rd brake light is out, your cruise control will not work.
Old Sep 16, 2010 | 05:28 PM
nitehawkjcb's Avatar
The cruise control is on a 2A fuse? I want to say mine's at LEAST a 5A.
Old Sep 24, 2010 | 10:47 PM
nelskin406's Avatar
checked third brake light, all is good
Old Sep 24, 2010 | 10:49 PM
nelskin406's Avatar
definitely a 2amp, replaced steering wheel control and another cruise box and no results, replaced both fuses and still nothing.? any new direction? am I looking at having the bcm reflashed?
Old Oct 3, 2010 | 08:23 PM
nelskin406's Avatar
ended up being the cruise disengage switch on the brake pedal linkage, thanks for the suggestions
Old Mar 5, 2013 | 08:27 PM
Benjamin Paz's Avatar
Default 2003 monte carlo ss idles very high
My Monte Carlo ss idles very high sometimes when u crank it and it stays like that sometimes while u driving and it won't idles back down I change the air temperature sensor the map sensor the idle control sensor and the throttle position sensor any idea what could it be thanks
RickCoMatic
Jan 3, 2008 08:50 PM
RickCoMatic
Dec 16, 2007 02:22 PM
dogmanx
Nov 17, 2006 03:25 PM
Seanzy
Jun 1, 2006 08:32 PM
montejass
Mar 22, 2005 04:04 PM
